Creo 3 customization : Drawing colors (syscol.scl)
  • June 13, 2018
  • 2 replies
  • 3717 views
I just upgraded my Creo 2 to Creo 3 and i'm doing config files.
I made a custom color config file (syscol.scl) and added in the "config.pro" file the patch to load it (system_colors_file parameter).
When i open a drawing, i does have the custom colors.
But when i go to File/Option/System colors/ , the good path is wrote and when re-select "Personalized" the custom colors are applied.
I probably forgot a parameter in a config file, could you help me please ?
Best regards,
    Best answer by Fredolavo
    Problem solved !
    I just found wrong parameters in the config.pro file ( "system_background_color" and "system_geometry_color").
    I deleted them, and it works !
    Fredolavo1-VisitorAuthorAnswer
    Problem solved !
    Mahesh_Sharma
    22-Sapphire I
    June 19, 2018
    You may accept your reply as correct answer for the post.
