CREO 4 - Snap dimension line to an edge
- February 21, 2018
- 5 replies
- 4402 views
Hello
I'm looking for a small but nice feature that I was using with CREO 2 but it seems to have disappeared from CREO 4.
In CREO 2, we could select a witness line (by the small white square at his base), hold "SHIFT" key and move the cursor along an edge: this would automatically place the witness line base at the end of the edge if the line was parallel to the edge or on this edge in other cases.
By the way, press the key "shift" + click on the white square of a witness line will lock its position (a small black circle appears).
Does anyone know if this is still possible with CREO 4?
Thanks ![]()
