Creo Parametric 3.0 Printing Problem
  • January 25, 2016
  • 3 replies
  • 2935 views
I am trying to print my sketches, and the information bar at the bottom of the screen keeps saying, "An error occured [sic] while executing the shaded print."  I do not have any trouble printing any other documents from my computer from Microsoft Office programs, but Creo is giving me problems.  I have tried the same procedure on several different computers, but to no avail.  What is the proper procedure for printing a sketch to avoid this problem?
Best answer by AmitDeshpande
Hi Matthew,
I did a search for that error message in our internal database and I found some old cases with the same error message, reported by other customers.  The resolution provided by the engineers is as follows:
Informed customer to set Pro/ENGINEER to wireframe display and then plot using MS Print Manager.
Please give this a try and let me know if it helps.
Amit
18-Opal
January 25, 2016
Hi Matthew,
Amit
mparker-21-VisitorAuthor
Thank you very much, Amit!  That straightened it out.  Without the wireframe display, it doesn't seem like Creo even communicates with the printer.
Thanks again,
Matthew
