Creo Parametric: Bold texts when symbol used.
  • December 17, 2015
  • 9 replies
  • 10670 views
Hi all, I'm getting bold texts on printed drawing outputs (hard print, pdf or postscript) whenever I use a symbol. See the attached picture. Does anybody know how to fix this? Regards
Best answer by MartinHanak
in CR2 M070:
  • I opened drawing
  • I changed font to win_font
  • I created PDF using Save As command and Use TrueType Fonts option
  • I created PDF using Save As command and Stroke All Fonts option
It seems to me that the output is OK. See attachments.
I guess that the problem is related to diameter symbol. Try to remove it temporarily from the note and test PDF creation. If problem disappears, then I guess that the problem is caused by bug present in CR2 M010 (you version).
MH
this can be caused by color assigned to text in symbol definition.
MH
akhadka1-VisitorAuthor
Hi Martin,
(Not sure if I'm doing it right) I've tried going into Note Properties - Text Style and changed the colour there but seems to have no effect. Do I need to make changes on System Colors? Please shed some light.
to be able to help I need example data created by you. Use How to attach file when you Reply to a discussion. to attach data files.
MH
Hi Steven,
I'm using Creo Parametric 2.0. I tried changing Note font type to default and this fixed it for me. However, if I change back to 'Arial' which I was using, error seems to remain.
Thanks for your help!
