Creo Parametric Material Files (Library)
Is there a good, current source for downloading Creo Material files? I am looking for commonly used metals and plastics. It seems crazy that every individual or organization has to create their own material library. I'm assuming this has been done many times, but cannot find a definitive source online.
-Scott
    Chris3
    Chris3Answer
    Creo 4.0 comes with the materials below. The reason that more materials aren't provided is because material properties are unique to the application. They can change with temperature, orientation, batch lot and risk. By risk I mean S, B or A basis. Aside from that companies don't want to get sued if you use those properties incorrectly and then your design fails (there are cases where this has happened).
    Aside from the default materials that come with Creo 4.0 below there are companies that provide this information:
    GRANTA MI:Materials Gateway for Creo‌
    Matereality
    Online Materials Information Resource - MatWeb
    Here are some other threads which contain materials:
    Creo Materials Library‌
    Materials.rar
    PTC response:
    Material database
    metal_aluminium_5052.mtl
    metal_aluminium_6061.mtl
    metal_aluminum_aa2014.mtl
    metal_aluminum_aa2024.mtl
    metal_brass.mtl
    metal_bronze.mtl
    metal_copper.mtl
    metal_low_melting_point_alloy.mtl
    metal_steel_high_carbon.mtl
    metal_steel_low_carbon.mtl
    misc_cardboard.mtl
    misc_medium_density_fiberboard.mtl
    misc_water.mtl
    plastic_abs.mtl
    plastic_acrylic.mtl
    plastic_hdpe.mtl
    plastic_hips.mtl
    plastic_ldpe.mtl
    plastic_nylon_6.mtl
    plastic_pet.mtl
    plastic_polypropylene.mtl
    plastic_polystyrene_foam_depron.mtl
    plastic_polyurethane_molded.mtl
    plastic_polyurethane_ureol.mtl
    plastic_ptfe.mtl
    plastic_pvc.mtl
    rubber_silicon.mtl
    wood_american_beech.mtl
    wood_american_mahogany.mtl
    wood_american_pine_wood.mtl
    wood_american_white_oak.mtl
    wood_balsa.mtl
    2-Explorer
    Hello  Scott Morris
    yes, it seems crazy, but my praxis is the same. l´m supplementing my personal material library (very primitive way).
    We don´t use FEM analysis, so the only different betwwen steel materials are: density, file name and description.
    In this case it´s not so complicated to create larger library.
    Don´t know where to donwload materials library.
    Hope someone will upload some surprise link
    Regards
    Milan Bonka
    Chris3
    Chris321-Topaz IAnswer
    Matereality
    Materials.rar
    PTC response:
    Material database
    metal_brass.mtl
    metal_bronze.mtl
    metal_copper.mtl
    misc_cardboard.mtl
    misc_water.mtl
    plastic_abs.mtl
    plastic_acrylic.mtl
    plastic_hdpe.mtl
    plastic_hips.mtl
    plastic_ldpe.mtl
    plastic_nylon_6.mtl
    plastic_pet.mtl
    plastic_ptfe.mtl
    plastic_pvc.mtl
    rubber_silicon.mtl
    wood_balsa.mtl
    Hello
    The files are compatible with Creo.
    Kind regards.
    Denis
    http://www.totalmateria.com/page.aspx?ID=Home&LN=FR
