Creo Simulate 2.0 and assigned mass properties
In Creo Parametric 2.0 the assembly was created. It contains one special component with assigned weight (this information overrides computed weight).
- Creo Parametric 2.0 reports correct weight of assembly
- Creo Simulate 2.0 reports incorrect weight of assembly - it uses computed weight for special component instead of assigned one
Is Creo Simulate 2.0 able to use assigned weight of component ?
Thanks in advance for sending information
Martin Hanak
