Creo View Express 3.0 Axis and plane display issues
  • October 31, 2014
  • 6 replies
  • 4758 views
Hi Eveyone,
This is my first post here so please go easy on me.
I use Creo 3.0 and would like production to use Creo View Express 3.0 for model interogation, freeing up resources in the design office.
Although this, in my opinion is a good idea I am unable to display axis or planes for native Creo files in view express.
This does not allow production staff to measure the models correctly.
My two questions are this,
Where can I submit a bug report for this issue?
What other free or inexpensive software can anyone think of to view and measure native Creo files.
Many thanks for any help given.
Have a great day.
Miles
Best answer by MartinHanak
Miles,
you can automate PVZ file creation. Maybe TrailMaker made by Jose Costa can do it.
And ... you are right ... PTC's own viewer should be able to display datum geometry .
Martin Hanak
Hi Miles,
Creo View is not my specialty and I don't have the Express version available for testing but I have a couple suggestions.
In Creo View Lite, I found under the Home tab > Filters icon > then select the "Model Construction Geometry" items.
Also, take a look at the following document. You should do the opposite of the resolution since you are trying to show planes and the document is for hiding them.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS34808
If this doesn't work let us know as other users may be able to suggest alternatives.
Miles,
I think that Creo View is not able to show datum geometry hidden inside native Creo files.
You have to configure Creo properly and export (ie. Save As) native Creo file as PVZ file. When you open PVZ file in Creo View, you will see datum geometry.
Configuration:
Locate export_pvs.rcp file in your Creo installation.
The path is similar to ... CREO3_LOADPOINT\Creo 3.0\M010\Common Files\text\prodview\export_pvs.rcp
Add the following lines at the end of this file:
adapter/outputDatumPlane=1
adapter/outputDatumCurve=1
adapter/outputDatumPoint=1
adapter/outputDatumAxis=1
Martin Hanak
Thank you so much for your suggestions.
Martin, You are right. I have tried this and it does indeed work.
The problem I have is that creating PVZ files for all of the models that production may want to interogate is just not workable.
So far I have been unable to find a viewer that will display the axis or planes to enable production to measure assemblies and models effectivly.
Do you think that PTC's own viewer should be capable of this?
Miles,
Martin Hanak
Brilliant, thank you so much, that will do it.
Well until PTC gets its act together and decides to fix this for native files.
I really don't understand how software is released with simple errors like this. Perhaps I am too naive, who knows?
I am not picking on PTC BTW as lots of software developers seem to have similar issues.
Miles
I have been told that this is not a bug and I should create an enhancement request.
Sorry but it IS a bug.
I guess I am just learning what it is like to be a PTC customer. Not good customer relations at all.
Oh well.
