18-Opal
August 17, 2018
Creo4 cannot select image?
  • August 17, 2018
  • 2 replies
  • 2244 views
It seems that images can only be selected if you are in the image editor, and the ALT button doesn't work.
Has anyone found a way to select images when not in that editor, or are we stuck with this?
Best answer by manjunathrv
As I know there is no other way to select the images. you need to be in the Image tab to select the image.
LawrenceS18-OpalAuthor
18-Opal
October 16, 2018
I found that it also helps to add the command to the right click menu to edit image.  Thanks for your help.
