Custom IFX Library in Creo 4.0
  • August 1, 2018
  • 10 replies
  • 11905 views
We have the full version of IFX, I had defined custom inch and mm libraries in Creo 3.0. The paths were mapped to a network drive and everything worked fine. Now with an upgrade to 4.0, I am having issues updating the mapping on other users PC's even though I had the correct paths in the sl_options file. I got it to work on mine but those steps are not translating to others. Could you provide the core files and directories I need to look at .
Best answer by OliverGräbner
Hi Kboyle,
your IFX option PATH_ABS_LIBRARY point to the wrong position.
You need to point to the parts directory.
Please try this and give me a short feedback.
If this does not work, please send me your complete parts folder. Please ZIP it.
Thanks.
Oli
kboyle1-VisitorAuthor
I think I figured it out. The sl_options file is no longer used. Now it's ifx_options. Why was so much changed, I do not see the benefit?
For simplicity.
What does sl mean when looking for an ifx option?
Now you look for the ifx_options file to edit ifx options.
