Custom symbol (text) with qutomatic Qty.
  • July 26, 2015
  • 3 replies
  • 1289 views
Hi all,
Im looking for the solution as noted below,
Right now im using a custom symbol (which was developed long ago) showing part name & qty. But i need to manually entering / editing the part name and qty. After a long search, now im using "&model_name" in the part name field. Its now showing the actual part name like PAD_SUPPORT_1. Is there a way to exclude the "_"?
Secondly please help me to add the qty automatically. I tried to enter &rpt.qty in the QTY field. But its not working. consider im trying this in a drawing for an assy which is having 6 different parts.
Im using WF4.0
Thanks in advance.
Pradeep,
to remove "_" character, you have to create relation defining new parameter, eg. MY_MODEL_NAME. You can find "_" character using search(string, substring) function. You can extract part of model name using extract(string, position, length) function. You can join several text strings using + operator.
rpt.qty parameter is related to repeat region. You can use it in repeat region tables and in repeat region BOM balloons.
Martin Hanak
Chris3
From Document - CS58396 (requires login)
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS58396
This is written for repeat regions, but it will also work in the part relations if you aren't using a repeat region. Just use rel_model_name instead of asm_mbr_name. As to the quantity, if you are working on QTYs for components in an assembly, what Martin mentioned will work. If you are just working on a component though, there is no way for the component to know how many times its used. It can not be automated. There is no way for the component to know that it is being used in an assembly on your computer but then also separately in another assembly on someone else's computer.
  • Users may use the below given example relations to replace "_" in part names displayed in repeat region tables.
  • Note:- bom_name is a user defined repeat region local parameter
if asm_mbr_name != "NULL"
/* Identify the location of the underscore
pointer1= search(asm_mbr_name,"_")
/* Verify if the underscore exists
IF pointer1 == 0
/* If it does not, name should not change
BOM_NAME = asm_mbr_name
ELSE
/* if the underscore does exist, assign the length of the name
/* minus the underscore to param index
segment_1=pointer1-1
segment1=extract(asm_mbr_name,1,segment_1)
length=string_length(asm_mbr_name)-pointer1
segment_2=pointer1+1
segment2=extract(asm_mbr_name,segment_2,length)
pointer2=search(segment2,"_")
IF pointer2 == 0
BOM_NAME=segment1+" "+segment2
ELSE
segment_3=pointer2-1
segment3=extract(segment2,1,segment_3)
length2=string_length(segment2)-pointer2
segment_4=pointer2+1
segment4=extract(segment2,segment_4,length2)
pointer3=search(segment4,"_")
IF pointer3 ==0
BOM_NAME=segment1+" "+segment3+" "+segment4
ELSE
segment_5=pointer3-1
segment5=extract(segment4,1,segment_5)
length3=string_length(segment4)-pointer3
segment_6=pointer3+1
segment6=extract(segment4,segment_6,length3)
pointer4=search(segment6,"_")
IF pointer4 ==0
BOM_NAME=segment1+" "+segment3+" "+segment5+" "+segment6
ELSE
segment_7=pointer4-1
segment7=extract(segment6,1,segment_7)
length4=string_length(segment6)-pointer4
segment_8=pointer4+1
segment8=extract(segment6,segment_8,length4)
BOM_NAME=segment1+" "+segment3+" "+segment5+" "+segment7+" "+segment8
ENDIF
ENDIF
ENDIF
ENDIF
ENDIF
Hi Pradeep,
Do you want to include quantity in bom balloon custom symbol?
While creating the symbol, create a note as \quantity\ and give variable text attribute as qty.
This works!
Srikanth
