DATE FORMAT
  • April 20, 2017
  • 3 replies
  • 3719 views
On our borders we used to have (In Creo 2.0) the format set to DD-MM-YY, but now in Creo 3.0 it switched around to MM-DD-YY. Is there a way to change this format so that it is DD-MM-YY or even DD-MM-YYYY?
Best answer by TomU
It depends on whether this value is coming from Windchill or from the &todays_date note.  One of these two config options should take care of the issue:
  • date_type_parameter_format %yyyy-%mm-%dd
  • todays_date_note_format %mm-%dd-%yy
Both can be adjusted to the syntax you want.
Hello Javier, I think it  based on your system date format, Check your system date time settings
TomU23-Emerald IVAnswer
jcolon1-VisitorAuthor
It was the todays_date_note_format... weird thing is that it was already set to %mm-%dd-%yy, but setting it to %dd-%mm-%yy achieved the desired effect.
We have no idea what is the underlying issue since the upgrade, but atleast now it is fixed.
Thanks!
