Datum Curve from Equation - Limits set by relation
- November 29, 2017
- 4 replies
- 3293 views
I am working with a geometry that uses a datum curve from an equation.
Certain parameters can be changed by the user in order to manipulate the curve.
The issue I am having:
Based on the parameters, two relations define numbers A1 and A2 which can limit the curve (see pic.).
Unfortunately, I could not make the curve's limits update when the parameters (and subsequently the relations) are set by the user.
It only worked like this until now:
- Update parameters
- Get failed geometry
- Edit definition of said curve
- Type in "A1" and "A2" which updates the limits
- Get the desired geometry
Is there any way to make this work without having to manually insert A1 and A2 each time?
Thanks!
