Define Piece Part
  • June 13, 2018
  • 7 replies
  • 2904 views
In NX there is a option as 'Enforce Piece Part'. By this option it will not be possible to add any other part/component so that resulting part will be only piece part, not an assembly part.
Is there any similar option/preference available in Creo?
Best answer by BenLoosli
NX is a different architecture than Creo.
NX allows multi-body parts, Creo does not.
NX uses a single file extension (.prt), Creo uses multiple extensions (.prt, asm, .drw, etc.).
There is no need for this option in Creo.
18 years using UGII/NX, 18 years using Pro/E/Wildfire/Creo.
StephenW
No. Creo does not support multi-body parts so this concept is not valid.
GaneshK1-VisitorAuthor
Hi @StephenW,
Thanks for the reply. I have attached a short NX video as a example.
StephenW
I won't download a video due to security issues.
Creo does not allow multiple parts in a part.
BenLoosli23-Emerald IIIAnswer
Hi @BenLoosli,
That clarify everything, Thank you! Smiley Happy
Can't we mark more than one reply as solution?
StephenW
No, you can only mark one as the solution.
I would mark Ben's as the solution since it is the most clear explanation.
