DESIGNATE PARAMETER MODELCHECK
  • August 24, 2017
  • 16 replies
  • 6810 views
hello,
is it possible to designate parameters already present in model via Modelcheck?
it seems not working...
thanks
Best answer by Mahesh_Sharma
Yes, It is working for me.
I have set it as below.
PRT_PARAMETER parameter_name STR EQ *
PRT_PARAMETER parameter_name STR EQ PDM
Mahesh_Sharma
22-Sapphire I
August 24, 2017
cspinelli14-AlexandriteAuthor
thanks,
but if i have already parameter in the model, ModelCheck Interactive will not designate the parameter.
i have only STARTPARM set to ERROR in *.MCH file, is it correct?
Mahesh_Sharma
22-Sapphire I
August 24, 2017
I don't think it will create any issue in that. Share your Modelcheck config files, that may help to check the cause.
