apapadopoulos-2
Designated Area on a thin part
  • August 28, 2017
  • 1750 views
When using Designated Area feature on the surface of a thin part the designated area is visible from the other site of the part. As if it is transparent part. I think this happen when the part is thin. Does anyone knows if this behave can be controlled with some accuracy setting?
Best answer by AmitDeshpande
I tested this out and did see the Designated Area show through the other side of the model, when it had a small depth value.  When I increased it, the Designated Area could not be seen.
I changed the value back to the original value, where the area showed on both sides, and then increased the accuracy.  The Deisgnated Area, could not be seen on the other side of the model.
Please give this a try.
Amit
18-Opal
September 13, 2017
Amit
