Different Color Surface from One Side to Another in Creo Parametric 2.0
I know you used to be able to do this in previous Pro/ENGINEER versions...when you colored a surface it would ask you if you wanted to color one side, the other side or both sides. Can you still do this in Creo Parametric 2.0? I can't seem to make it work! I have a previous model that has a quilt that is colored green on one side and red on the other. I can't re-create this in Creo Parametric 2.0. I know that I can make 2 surfaces with a very slight offset and make it work, but I should be able to make this work?
