Different shapes with the same member?
  • May 11, 2017
  • 2 replies
  • 1970 views
Hi!
I'd like to make a resistor artifact in schematics 3.0. Is there a way to add both a European and an American circuit shape to it with the same ports and same name? If I put or copy the ports It always increments the name value by one, so on one shape it would be 1-2 on the other 3-4... The question is interesting in the x-ref shape area too, because if I'd like to make a cross reference shape of something it would normally have the same pin numbering than before, I cannot manage this now. How should these suppose to work out?
Thanks!
Laszlo
Best answer by jstone
Laszlo,
Use "reassign shape" on the port when you create the shape.  This way you re-use the ports from the other shape.
jstone12-AmethystAnswer
Laszlo,
glászló1-VisitorAuthor
Jeff!
Thanks for the fast answer again! I've quickly tried the reassign shape option, it works fine! Thanks again!
Regards!
Laszlo
