dimension
  • July 6, 2016
  • 2 replies
  • 1535 views
When I try to put a driven diameter dimension in my detail drawing view, it comes in as a radius callout.  Is there a wetting to change this?  If not, How do I change the properties of the hole callout to recognize the diameter instead of the radius?
Best answer by TomD.inPDX
Click the same arc twice before placing the dimension and you will get a diameter value.
This is normal behavior for Creo.  Same for sketches.
You can also right click the dimension and change between radial and diameter.
rmogensen1-VisitorAuthor
