Drawing not allowing new views, tolerances
  • November 3, 2017
  • 5 replies
  • 9652 views
We just recently (this last week) upgraded to Creo4 and Windchill 10.2 from Wildfire 3 and Intralink 3.4... I'm trying to work on drawings, and am unable to add tolerances, tables, new views. I created a new part using legacy start parts and drawing formats and the tolerances are turned off (greyed out). The pictures I've attached are from a legacy drawing/assembly. I've never seen this issue anywhere before, with past upgrades I've done.
Any ideas of what I've turned off? Based off of what I have been able to find, tol_display is set to yes, and that should allow at least tolerance display and editing. I can do so in the model, but am unable to make them appear in the associated drawing.
Best answer by Mahesh_Sharma
For tolerance, set detail option tol_display as yes. Open any drawing File > Prepare > Drawing Properties > Change Detail options > Change the value of tol_display as Yes. Once Done, change the tolerance of Dimensions.
20-Turquoise
November 3, 2017
Is the drawing you are attempting to edit locked in the workspace?
Mahesh_Sharma
22-Sapphire I
November 3, 2017
Seems to be licensing issue. Contact your IT and reconfigure Creo 4.0 and add all available licenses (specifically Detail) in startup configuration.
The drawing is not locked, but it appears to have been a licensing issue, at least for the majority of my problem.
I'm still unable to add tolerances to dimensions.
Mahesh_Sharma
22-Sapphire I
November 3, 2017
Reinstall creo
Update Dat Code
Set default config.
Reset all mapkeys and Shorkey
Restart system.
