Drawing Template and BOM table
  • November 7, 2014
  • 8 replies
  • 3580 views
I have created a format and a template for creating new drawings. In the format I have created a BOM table with 2D repeat regions, so it automatically populates when an assmebly is added to the drawing. I then created a template that uses that format. The problem I am having is that the BOM table will not populate when I create a new assembly drawing using the template. If I create a new assembly drawing using the format the BOM table populates like it should. In my attempt to figure this problem out, I have tried adding a table to the template separate from the format and I still am not getting the BOM table to populate. Any ideas on what I am doing wrong? Thanks.
Best answer by kgwmu
yes, everything was added in the template mode.
Did you have the template in "Template" mode before applying the format to it or manually inserting the BOM?
kgwmu1-VisitorAuthorAnswer
Does the BOM work correctly if the table is manually added directly to a drawing (with the assembly already present in the drawing)?
