dual dimension shows comma instead of a decimal point?
  • January 14, 2013
  • 4 replies
  • 9701 views
why does the dual dimension show a comma instead of a decimal?
Best answer by John.Pryal
try setting the dtl config option "decimal marker" to "period", it is probably set to the default "comma_for_metric_dual", which is why you see a comma.
Regards
John
Regards
John
thank you very much!
Patriot_1776
Check to see if the ASME standard does not specify a comma instead of a period first if the dwg is being checked to ASME.
