8-Gravel
July 21, 2013
DWG to PDF using Creo
  • July 21, 2013
  • 4 replies
  • 5107 views
Hi All,
Is it possible to write a commandline utility to convert DWG file PDF using Creo ? Pl. guide me
thanks,
Kumarappan.S
Best answer by MartinHanak
Kumarappan,
use information located at the end of the attached file.
Martin Hanak
Um, why not just print the DWGs to PDF?
ks-28-GravelAuthor
8-Gravel
July 22, 2013
Need as a batch file to invoke programmatically from java!
Hi, Kumarappan.S.
As for me, I have seldom tried to convert DWG file PDF using Creo. I wonder have you ever worked it out? Do I need another 3rd party manual toolkit? When it comes to PDF converting process, I have another question, I wonder have you ever tried to convert pdf to other image files before? As for myself, I am testing the related PDF to PNG converting, PDF to BMP converting , and PDF to JPG converting programs these days.  Do you have experience about it? Any suggestion will be appreciated. Thanks in advance.
Best regards,
Pan
Kumarappan,
Martin Hanak
