Feature was created, but is not currently displayable in any view.
  • May 26, 2017
  • 4 replies
  • 2679 views
I wanted to do a very trivial operation: create a reference datum plane in a drawing view.
I did, but the message, with a yellow exclamation point, was:
The plane was in the "Datums" category on the view and in the Assembly, but was dimmed. The only operation I could do, as far as I tried, was "erase-unerase".
What happened?
Nic.
Best answer by dm-4
Try un-hiding layers in layer tree on the drawing view.
dm-41-VisitorAnswer
StephenW
Are you referring to a GD&T set datum? I typically make these in the model simply to make sure I am getting the plane defined exactly as I want it.
Yes. But also in the drawing should be defined as "you want".
18-Opal
May 26, 2017
Hi Nic,
Can you please elaborate on what you are seeing?  If you can, please upload some images of the issue.
Amit
