filters in repeat regions
  • February 9, 2015
  • 6 replies
  • 2603 views
Is it possible to make a rule (in repeat region) that filters whole subassemblies (including all parts) according ptc_common_name of the subassembly?
thanks in advance.
T.
Best answer by SYNDAKIT
I would give the subassemblies a ptc_common_name value of something like "filter_me"
then create a filter rule that is asm.mbr.ptc_common_name != *filter_me*
does this sound like somthing that might work for your application?
if not i have a couple more things you could do but they are just a little more in depth.
are the other things in your region parts or are they all subassemblies?
thlavinka1-VisitorAuthor
THERE ARE ALSO PARTS IN THE REGION
SYNDAKIT15-MoonstoneAnswer
