Find part in model tree by selecting in viewport?
  • April 1, 2017
  • 7 replies
  • 5026 views
Can you select a part in the view port and have the assembly and sub assemblies which contain it expanded in the model tree? This would make it easier to find a part without extra clicks. Especially in large assemblies. From my searches I can only find solutions that don't work for me. I learned about a command called "one" that did exactly this but it doesn't seem to exist anymore. I also saw people using a menu in the viewport by right-clicking on components which had a command called something like "find in model tree" but I don't get this right click menu.
StephenW
What release and version of Creo Parametric are you using? Locate in model tree was not available in older releases.
vu182921-VisitorAuthor
I'm using Creo Parametric 3.0. I should also add that I'm using an academic student license. Now that I think about it, if the student features are the problem, then I guess this post really belongs in the academic support section.
As far as I know there is no difference in interface between the Commercial and Academic versions beyond which modules are available.
Where did you find a command called "one"?
There is an Expand Branch that you might be referring to. The Expand commands are not in the ribbon by default so you need to add them if they are still present. The Collapse commands also need to be added if you intend to use those.
