FIXED LENGHT OF DATUM CURVE
  • February 27, 2017
  • 7 replies
  • 3717 views
hello everybody,
is it possible to set a relation in which fix lenght od datum curve?
thanks
Best answer by dschenken
No. And the reason is that the flex of the cable is a deformation relaxation optimization problem** that depends on the flexibility of the cable and the end conditions, which is far above the capability of a parametric modeler.
What most people do is look at the installed length of the cable and use that value to drive the straight length so they part as-procured will be long enough to be installed. You also need to verify that the curvature of the cable isn't higher than allowed (or the radius smaller, depending on your viewpoint) and, if that's a push-pull cable, that the path doesn't create too much internal friction due to the routing. While the curvature can be checked, the friction is beyond the parametric modeler to determine.
**you would be looking for the case of minimum strain energy stored in the cable in both tension and torsion, which is where the end conditions can have a big influence.
Only straight ones by managing the nodes used to create the curve.
Technically, the answer to your question is no.
Datum curves try to follow your selections.
It doesn't do sharp corners unless you specifically make the segments straight.
If you have only straight segments, you can do the math on the selected references instead.
In other words, you have to reverse engineer the curve's length regardless.
...curious to know, however:
What if you create your curve; measure it's length (measure feature); and scale the part between the current length and the desired length(?)
I did something like that to simulate a bent flat spring. There's an equation for cantilever beams that gives the curve based on the load, but it assumes the deflection is very small so it doesn't account for the rotation of the beam elements.
As an exercise I wanted to use it for larger deflections, so I first created the uncorrected curve, then used a measure of its length to create a corrected curve with a shorter X-direction length to make up for Y-direction deflection. I ended up using a series of 3 iterations of curves to get one that ended up matching the finished length to the original length within a small amount.
I took a real part and compared the fudged curve and it was very close, close enough to match the initial installed position of the steel strip.
The main thing I wanted after that was for Relations to support user defined functions, but I suppose those and loops aren't coming any time soon.
