Friday Rant
  • May 14, 2010
  • 23 replies
  • 3703 views
As a long time user of proe and a having a continuous rant on:
The extra clicks that we have to go thru when we want to leave a feature or delete something.
Yes, when weclick on "delete" I really want to delete the feature!!!!!
Whenwe want to leave a feature "incomplete" yeswe really want to leave a feature incomplete!!!!!
Yes, when I want to leave sketcher, I really want to leave sketcher and all the other "do you really want to's and we have tomouse click our way outwhatever we are trying to leave andthat we have to go thru, please give me an option to turn off all these annoying mouse clicks! i'm a veteren user and I know what I'm doing!
And I'm not even talking about the mouse travel!! Click on something and a window pops up ON THE OTHER SIDE OF THE SCREEN! Hello carpel tunnel ___
I will be atOrlando, is anyone interested in meeting on this? let meknow. WF 5is no better.
John
They've removed Query Select? Which version? I'm guessing WF5, as
we're on WF4 and it still works for us...
That's approaching a killer reason *not* to upgrade.
Jonathan
Query Select is there in WF4 M140 and WF5 M030. It's there whether prehighlight is on or off. Just slightly different for each.
When you right-click your mouse arrow over something...
and pre-highlighting is on, you just keep right-clicking and it will highlight in succession each of the possible features/entities. Pick the feature/entity you want. You can also hold down the right mouse button and select from the pop up menu the option Pick From List.
and pre-highlighting is off, when you hold the right mouse button down a dialog box will display with either Pick or Query. However, you do not have to hold down the right mouse button to get the Query option. Just by right-clicking and not holding down then it automatically changes to Query. Once you select something then the Pick From List dialog box displays.
You can right-click and scroll through the Pick From List dialog box whether the pre-highlighting is on or off.
Steve G
<beginrantfix>
Uh....have you guys tried just holding down the Alt key? It stops the prehighlight and still allows a RMB Query / Pick from List.
<endrantfix>
