kdirth
Full Screen Mode Pulls Window to Main Screen
  • February 27, 2018
  • 2 replies
  • 1986 views
When I enter full screen mode the window gets pulled to the main monitor.  Is there a way to get it to stay on the monitor I have the window in?
Best answer by MartinHanak
this is know issue ... see https://www.ptc.com/en/support/article?n=CS280192
You can probably move your primary to the external.  Do other programs function as expected when you can maximize on the current screen?  If so, you have good reason to submit a support case.  Actually, if you have maintenance, you always have a cause to submit a support case 🙂  Obviously I don't use dual screens but I do know you can change your primary screen in your monitor setup.
