Has anyone ran into this "components model is missing" situation?
  • January 23, 2012
  • 676 views
Pro Guru:
If I bring up a top level assembly which have two components (MS35333-40
instance and M16878 wires instances) located in our library, a failure
diagnostic window pops up with a "components model is missing". I try
"find components" and point them to the library location, Pro/E prompts
that "selected model does not match missing model". However, if I load
these components into memory first then the top level assembly opens fine.
What am I missing?
Your comment and help is greatly appreciated.
Frank
Your not using, Windchill or Intralink? If not, make sure you have
all your paths listed in your config.pro file.
Gary
