11-Garnet
June 4, 2015
Hi, it's possible open a catia file and save it without any kind of editing
  • June 4, 2015
  • 9 replies
  • 4830 views
Hi, my question is:
action sequence : Using Unite Technologies it's possible open a catia v5 file, don.t make any kind of editing, save it as catia file .
goal : when i open it again in catia have the feature tree again.
thanks a lot for your help
Best answer by bduncan
NOT POSSIBLE
bduncan17-PeridotAnswer
NOT POSSIBLE
bragini11-GarnetAuthor
11-Garnet
June 6, 2015
I also thought it was impossible, but I was hoping never edit the file there was any possibility.
Thank a lot Bye Bye BLU
MAYBE the futrue version of Creo
Hi Fabio,
If you add your CATIA part to CREO assembly and save assembly without changes to that part you can still open it in CATIA and have your features.
Why would you save your CATIA part if there was no changes to it??
11-Garnet
June 7, 2015
Hi Davor
it's right i've not  needs to save the part .
i've to save the assembly in my windchill databese then checked out the catia v5 part and open it with into catia. I've not a licence of catia and i wasn't sure if the catia part has all featur again.
Thank a lot for your attention
Actually even if you make changes to part it will remain with its features in its native software. When you make changes to CATIA part CREO asks you if you want to convert part to creo part or no.
Anyway you choose he will use data from CATIA part and keep changes in separate CREO file. So you can still open your CATIA file with its features.
But if you want to save that part with changes to CATIA format if wont open it in CATIA with any features.
