How can I hide model sketch lines in a drawing?
  • July 7, 2015
  • 4 replies
  • 13329 views
How can I hide model sketch lines in an assembly and drawing? Hiding the sketch in the model temporarily solves the problem in the drawing. The sketch lines will reappear after the part is closed and opened.
Best answer by tzych
I found a way to keep the sketches hidden. I hid the Datum Curves layer. Then under the VIEW tab->Visibility->Status->Save Status, I was able to keep the layers at their current status when the drawing is reopened.
Mahesh_Sharma
22-Sapphire I
July 7, 2015
You may try using layer to control the display.
Create a layer > Add sketch in the layer > Hide layer and save status.
You could also make a rule based layer so that any sketch you make in the model tree will be placed on this layer
tzych1-VisitorAuthor
