How can I tie a revision triangle to a row in my BOM table?
  • May 10, 2017
  • 9 replies
  • 4736 views
We put our revision triangles next to the part number in the BOM table that was effected.
When an item is added or deleted the table shifts causing the revision triangle to be on the wrong item.
Any help would be great.
Best answer by mender
Not sure if this would work, but did you try putting a Repeat Region > Comment column at the end of the table (possibly of tiny column width) using &sym() to include the symbol?
StephenW
Unfortunately it is not possible to "attach" a symbol to a specific repeat region in a BOM table.
mender12-AmethystAnswer
kmacy1-VisitorAuthor
Is a comment column different than just clicking table edit>add column?
