how do I create a break out view?
  • March 28, 2016
  • 3 replies
  • 11319 views
how do I create a break out view in a Creo Drawing view?
Best answer by StephenW
Create a cross section in the model where you want the breakout to be. Then, in the drawing, use the section as a local section (instead of full x-section).
StephenW
StephenW23-Emerald IIIAnswer
Curtis1-VisitorAuthor
Thank You
Emeritus
March 29, 2016
Good day Curtis,
Looks like Stephen's solution fixed your issue; would you please take the next step and mark his answer as "Correct Answer?"
This way others reading the thread know there is a solution, in addition, it makes the solution easy to find.
Thank you,
Toby
