How do I force a dimension type in sketcher? Creo 2.0.
I have a slot that is .6° off the bottom of the part. I have created a construction line between the ceter points of the two arcs. When I try to dimension an specific angle it will only pick the end points of the line. In Catia (my main program) I can choose a dimension type like angle before making the dimension and the program creates an angle dimension. I can't seem to get creo to behave the way I would like it to. That is forcing the dimension creator to limit it'self to an angle dimension. How do I accomplish this task?
I am converting parts from Catia into Creo and need to match the dimensioning scheme. So an angle dimensoin is required.
