How do I get all surfaces coloured?
  • November 14, 2017
  • 6 replies
  • 3548 views
Hello together,
Example:
I have 2 or 10 fitting holes like 10H7.
Could I get the surfaces from this holes coloured very easily? Not by single clicking every surface 😉
So If somebody shows only the modell not the modelltree easy know this holes are!
Thanks 4 ur help.
Greetings
SJI
Best answer by dgschaefer
You can use the find tool to do this.
Set the following:
  • Look for surface
  • Look by feature
  • On the History tab, select number
  • Set the number range for the features that you want
  • Click find now and all the surfaces of those features will be found
  • Select the ones you want, click the >> button to add them to the selection
  • Choose the color you want
SJI4-ParticipantAuthor
For Example:
One trick is to color the solid one color, then change the surfaces to another color. When you do a hole or other cut operation, the solid color will be where the cut is.
Unfortunately Creo cannot do this easily or automatically.  You can change your selection filter to "Intent Surface", but you still have to manually pick them.
Set the following:
  • Look for surface
  • Look by feature
You can also find surfaces of features of a certain type.
For all hole features use the Attributes tab like this:
Thanks 4 all the help!!!
