How do you change the tolerance in 3D annotations?
  • March 2, 2015
  • 1181 views
I am using the 3D annotation tool in Creo 2.0, and I am having trouble changing the tolerance on ordinary dimensions. When I view the dimension's properties, the Tolerance mode is set to "Nominal" and is grayed out. I cannot change it symmetric, +/-, or anything else. What do I need to do in order to be able to make this change?
Best answer by StephenW
In your config.pro, make sure TOL_DISPLAY is set to yes.
StephenW
StephenW23-Emerald IIIAnswer
