How to add a Relation to BOM table to reference one parameter or another.
I'm generating a simple BOM table (Column headers as; Part No, Description & Quantity). The assembly comprises of components modeled by the local design team and parts from overseas. I need the table to populate the 'Description' cells (driven from a part Parameter),using either of the defined Parameters i.e 'asm_mbr_Description' or 'asm_mbr_Bezeichnung'
I believe this can be achieved by defining a Relation to the Table Repeat Region, but I am struggling to write (and apply to the table ) the correct script. This is what I've drafted:
if exists ("asm_mbr_DESCRIPTION")
bom_no=asm_mbr_description
else
bom_no=asm_mbr_bezeichnung
endif
Many Thanks.
