how to add entry ports to an existing part?
  • September 29, 2015
  • 3 replies
  • 2272 views
Best answer by AmitDeshpande
So you should be able to create coordinate systems and designate them as Entry Ports.  I would suggest you go to the Help Center and type Entry Port in the Search.  You will find detailed information there.
Amit
18-Opal
September 29, 2015
Hi Ayman,
Please elaborate on what exactly you are trying to add.  Is this for a cabling or piping assembly?  Are you trying to model the entry port, i.e. create geometry?
The entry ports on cabling or piping assemblies are designated by coordinate systems - CSYS.
Amit
azohbi1-VisitorAuthor
Hi Amit,
So I downloaded a step file for a connector I am using in my design. But it doesnt seem to have any entry ports because when I try to do my harness routing i cannot find any port to route to.
Thank you
18-Opal
September 29, 2015
Amit
