How to eliminate the message
  • September 23, 2015
  • 8 replies
  • 3384 views
Hi, I am facing an issue here.
When I created a drawing (use the template from my company), a message always occured.
Formart properties(Drawing properties) of the template such as the below:
I just think there are some relations between the message and the options .
And if so, Can I delete the "aux_line_font"  from the tree options?
        Many thanks !
Best answer by MartinHanak
to remove aux_line_font 21 SOLID option you have to change aux_line_font 21 SOLID to aux_line_font 21 SOLIDFONT
MH
Mahesh_Sharma
22-Sapphire I
September 23, 2015
There is an article CS20718 regrading the same.
This may help you.
hdu1-VisitorAuthor
Thank you for your reply !
However, my Basic PTC.com Account have not sufficient privileges to access to the area of eSupport.
Could you deliver the article CS20718 converting pdf  by e-mail ?
thank you very much !!!
Mahesh_Sharma
22-Sapphire I
September 24, 2015
Here is the resolution [art of document.
  • The format references line styles that are not available
  • Remove the references
    • Select File > Drawing Options and change aux_line_font 26 DXFFONT_#  to aux_line_font 26 SOLIDFONT for each font
    • If aux_line_font is listed more than once repeat the same procedure for each entry
    • Two additional aux_line_font options appear to be added but they will go away after updating the drawing
    • Select Add/Change > Apply > Close
    • Select View > Update > All Sheets
