how to flatpattern a elbow in sheetmetal
  • May 8, 2015
  • 4 replies
  • 2266 views
i want to flat a elbow in sheetmetal to measured it's development length?
Best answer by BenLoosli
Sheetmetal only works on sheet types of parts, not tubes.
Your best bet is to appriximate the elbow as a sheetmetal part and flatte that.
BenLoosli23-Emerald IIIAnswer
Akshay, you need to give us more detail. Is the elbow a rectangular cross section? Circular? If it's not designed for a certain way, then you will have to stretch the material when you form the flat pattern into an elbow. Calculating the allowable stretch is not something Creo can do.
adeshmukh1-VisitorAuthor
it's circular section.
Also I have to show bending lines in part as well as in drafting
**Confirming Ben's response and marking as such.
