How to get the value of a parameter in a family table instance with VBA?
  • November 3, 2016
  • 2 replies
  • 1676 views
I have an Excel sheet that lists all of an assembly's components, and a "Part Number" parameter for each component. My problem is, the parameter isn't read if the component is a sub-assembly, or a part that is an instance of a family table.
Does anyone have an example of how to check if the component is a subassembly or FT instance, and if so...how to get a parameter value from it?
Here is a code snippet of how I'm reading the parameter from every componet (which works if its a part)
    For iCnt = 0 To (pathArray.Count - 1)
            Set eachPath = pathArray.item(iCnt + 1)
            Set mdl = eachPath.Leaf
            ' if model is part
            If mdl.Type = EpfcModelType.EpfcMDL_PART Then
                  iRow = iRow + 1
                  Range("Components").Cells(iRow, colFileName).Value = mdl.Filename
                  Set paramOwner = mdl
                  Set params = paramOwner.ListParams()
                  For i = 1 To (params.Count - 1)
                          ' Get part number and extrusion
                          Set param = params(i)
                          Set paramValue = param.Value
                          Set paramName = param
                          If paramName.Name = "PART_NUMBER" Then
                                  PartNumber = paramValue.StringValue
                                  Range("Components").Cells(iRow, colPartNumber).Value = PartNumber
                                  Exit For
                          End If
                   Next i
               End If
            End If
    Next iCnt
Best answer by cstarnes
The problem was I was starting at index one on a zero-based array (ListParams).
Seems to be working now.
You have there condition
so it cannot process nothing else but parts.
What is in the pathArray list? How do you get this list?
Tom
cstarnes12-AmethystAuthorAnswer
