How to import XML files in order to add parameters?
  • March 10, 2015
  • 0 replies
  • 1466 views
I want to know more about External Analysis and I want to import XML files in order to add parameters and values in Creo Parametric.
I've already exported an XML files with an example of Mass and Density.
I want to do the way back and change values by using the "Read" step but it doesn't work and I have the following message :
Is someone has an idea about how the XML file should look like in order to be read by "External Analysis" ?
Thank you,
Farida S.
