How to move a sub-assembly from assembly to another
  • May 9, 2016
  • 4 replies
  • 4349 views
Greeting-
I have a sub-assembly (a) within another sub assembly (b), and I need to relocate this out place it at the same level as assembly (B).  How best to do this as drag and drop don't work.
thank you
Best answer by kdirth
My guess would be that you have something in your top level assembly constrained to it.  Remove these constraints, move the sub-assembly, and recreate the needed constraints.
For whatever reason, CREO will not allow a sub-assembly or part to be relocated up when there are constraints in the upper level assembly referencing the sub-assembly or part.
kdirth
kdirth21-Topaz IAnswer
Thanks Kevin, for some reason I was able to drag and drop in out of the assembly, after a few attempts and it kept the constraints as well.
Frank
