How to print multi file in a project
  • September 17, 2017
  • 4 replies
  • 2351 views
Hi all,
Is there any way to print or create a pdf file for all drawing in a project? i still have to print one by one.
Best answer by LEONIDGUREVICH
"The Pro/BATCH module allows the creation of export files without having to retrieve each object file independently during a session of Pro/ENGINEER"
<Load Point>\Parametric\bin\ptcdbatch.bat
Zero14841-VisitorAuthor
Thanks @LEONIDGUREVICH,
I haven't install Distributed Computing Extension before, so i can't find that file. After reinstall i can see it now but still can't export file, i need more time to investigate it.
By the way, is there any way i can show drawing of each item quickly on parametric window and don't need to find exactly file name in open windown?
Thanks.
see https://community.ptc.com/t5/Creo-Modeling-Questions/Trailmaker-0-3/td-p/48278/page/2 discussion.
I attached the last version of Trailmaker that I have.
