How to reference another dimension like @D7 in callout for @D? (Creo 3.0)
  • August 28, 2018
  • 2 replies
  • 6764 views
I'm new to Creo, so it's hard to know how to ask for what I would like.
When in the dimension properties of one dimension, in the Display tab, I see the default text is "@D" which is the current dimension.  Can I add something like @D5 to also reference another dimension at the same time?
Best answer by StephenW
Use &d7 instead of @d7
So your specific one would be @d  &d7 and would show the 2 dimensions on the same line in the original dimension
StephenW
StephenW23-Emerald IIIAnswer
JZazzi1-VisitorAuthor
That did it, thank you!
