6-Contributor
September 27, 2018
HOW TO THE ADD UPPER AND LOWER TOLERANCE IN THE NOTE BY USING CREO 3.0
  • September 27, 2018
  • 4847 views
HOW TO THE ADD UPPER AND LOWER TOLERANCE IN THE NOTE BY USING CREO 3.0 -
We have option in the CREO 2.0 like adding the @++0.00@#@--0.00@# but in the CREO 3.0 did not accept as tolerance format in the note. Please suggest
Best answer by Kevin
Try the following: {0:@++0.00@#}{1:@--0.00@#}. It should keep the format for the text segments separate.
Kevin1-VisitorAnswer
