How to use Edge Display to hide lines (dimmed lines) in creo drawing?
  • November 8, 2017
  • 5 replies
  • 12615 views
Can anyone help me with this,
I have this situation. I need to hide some lines in creo drawing, so I started using Edge  Display tool from
Layout>edit> Edge Display
So it removes some of the solid lines, but some of the dimmed lines were unable to hide. Please see the attached Screenshot.
Please suggest a better way,
Thanks and Regards,
Sundar Dannana.
Best answer by sundardannana
This problem has solved. I just switched off  this option
I have given hole with tapping. when I switched off this feature. Then it worked for me.
Anyway thanks,  @dschenken , @MartinHanak
please upload test drawing. Pictures are insufficient.
The usual cause of section problems is coincidence of the section plane with some part of the geometry. Moving the section a very small amount will often rectify the situation. There is also the sometimes condition that the section view direction is not correct for the view the section is in, causing all sorts of oddities.
The usual difficulty in erasing edges is that the already hidden edges are still available for selection so that if there are overlapping edges the one that is selected first will continue to be selected. This usually presents as a line that refuses to be hidden or removed when all that is happening is the first one keeps getting reselected. Use query-select to select the next one.
If neither of these apply then, as Martin Hanak suggests, the model and the drawing will be required to figure out the particular problem.
sundardannana1-VisitorAuthorAnswer
Dale_Rosema
I think you just switched your holes from threaded holes to clearance holes. It may print without the hidden lines, but if others read your data you may not get what you are looking for.
