How to write mathematical equations in relation dialog box, such as cuberoot, cot, tan, cosine etc??
  • January 25, 2018
  • 8 replies
  • 5841 views
Hi All,
Let take is a parameter(d1), ds,g1 and toe...
now i want to write equation for below farmulaes, how can i write, please suggest...
regards & thanks!
Shravan
Best answer by KenFarley
Gotta put that 1/3 in parentheses. Operator precedence.
27^1/3 = ( 27 ^ 1 ) / 3 = 27 / 3 = 9
27^(1/3) = 27^0.33333333 = 3
It should all be explained in the help section under expressions.
I am not sure about the cuberoot value.
KenFarley
R1max = 0.505 * d1 + 0.069*d1^(1/3)
ds = p * cos ( tau / 2 ) / sin ( tau / 2 ) - 1.04 * g1 - 0.76
The only term I'm not sure of is the fractional "power", "^(1/3). I've never had need to use such an expression. You should also take a look at the reference materials people have suggested. The syntax is similar to most programming languages with respect to operator precedence, etc.
All "variables" above ( such as "tau", "d1", "R1max", etc.) are assumed to have been defined as parameters or model dimensions.
srajbhar1-VisitorAuthor
It worked! thanks!
This sounds like an excellent case for using an embedded Mathcad worksheet instead of Relations.
Mathcad Express is free from PTC, and no additional licenses are necessary to embed a worksheet. This functionality is available from the Applications tab.
Unless I'm mistaken, these equations are of fundamental importance in the urine extraction process.
Or as we call it in Scotland, taking the piss!
Hi, for power and root functions the format is ^x and ^-x, so cube root will be ^0.333 or ^1/3
KenFarley
KenFarley21-Topaz IIAnswer
