3-Newcomer
May 30, 2017
Importing a STEP file into a Creo 3 start part file
  • May 30, 2017
  • 4 replies
  • 10430 views
How to import a STEP file into a Creo 3 start part file?
Best answer by Mahesh_Sharma
Suhair,
Do you want to import step file using start part template or import in start part itself?
When importing in Creo 3.0 check "Use templates" in Import new model dialog to use start part template.
About import in start part, use Get Data > Import
Mahesh_Sharma
22-Sapphire I
May 30, 2017
Suhair,
StephenW
Open a new part using your start part file. In the model tab, use GET DATA drop down arrow, IMPORT, select your step file from your file system.
Chris3
sghannam3-NewcomerAuthor
3-Newcomer
May 30, 2017
Thank you so much for your responses. I was able to import into the start part file by selecting a template
