Importing Excel Tables into Drawing Formats
  • December 9, 2014
  • 5 replies
  • 11223 views
Hey Peeps,
I was wondering if it is possible to import tables pre made in Microsft Excel into drawing format files. In addition if this is possible if it can parametrically update when the xl file is modified. I am currently working in WF5.
Jeff
Best answer by SYNDAKIT
Yes, layout>object> then select the create from file option > then select microsoft excel worksheet.
jvo-21-VisitorAuthor
Bump.
SYNDAKIT15-MoonstoneAnswer
Is it possible to format the table import into a format input prompt?
I would have to take a look at it. but just to make sure i understand; you want a prompt to ask you which table to use when creating a new drawing?
